Graham Slee MC Riaa Fanfare - god lyd til få penge.
A Great Place To Start With Moving Coil. This phono preamp will give you a superb musical performance from low-output moving coil few others at the price are able to match.
The 'Fanfare' is from our budget 'Gram Amp' range which offers fabulous performance with excellent value for money.
The Gram Amp 3 Fanfare is for low output moving coil cartridges, and is best used into a preamp, integrated amp or receiver's line/aux input.
It is supplied with a basic ("green energy") power supply which self adjusts to your voltage, and with power-pins fitted to suit your power outlet — and you can upgrade by swapping over to PSU1 power when you're ready.
