Her er du: Tilbudsavisen - Annonce 26. april 2018 | 13:26
Redaktionelt
Forsiden
Nyheder
Anmeldelser
Indsigtsartikler
Besøgsartikler
Arrangementer
Interaktivt
Køb, Salg & Bytte
Tilbudsavisen
Debat Forum
Services
Kontakt
Søgning
Søg efter produkter i Tilbudsavisen
Udskriv annoncen
Icon Audio - PS3 mm+mc
Annoncør: HighEnd-Sound
Kontakt: infohighend-sound.com
Produkttype: RIAA
Annoncetype: Tilbud
Tilbud:
Icon PS3 mm + mc er lidt mere af alting, mere detaljer uden at den dejlige bløde lyd går fløjten. Den kan naturligvis bestilles kun som mm riaa.
Icon Audio PS3 mm+mc RIAA
PS3 kan benyttes som forforstærker da den er forsynet med volume kontrol, men fungerer naturligvis rigtig fint kun som RIAA
Specifications and Features
• Built in volume control, will drive most power amps
• Max output 50 volts for massive headroom.
• Two turntable inputs 1xMM 1xMC/MM
• Signal to noise ratio -88db MM unweighted
• Stereo/mono switch for better S/N and distortion from mono and worn stereo records
• Valve rectified power supply
• Valve regulated power supply
• Twin Choke for exceptional smoothing
• Separate Power supply for lower noise
• Comprehensive manual supplied with tube change info
• All hand wired point to point
• No printed circuit board to ‘colour’ sound
• Japanese Blue ALPS volume pot.
• All Triode valves
• 4x ECC88 1x 6SN7 (pre-amp)
• 1x EZ80 1x ECC83 1x 5687 (power supply)
• Sensitivity: 3mv for 1.26v output (0.3mv MC)@
• Gain MM 53db MC 72db
• Load: imp: 47k MM, 100 ohms MC
• Output source impedance 50 ohms
• RIAA Freq response 20hz-20khz +0 – 0.5db
• NO feedback used, Passive RIAA
• Low noise oversized 2w metal film resistors
• Blue LED mains indicator
• Polypropylene audio capacitors
• Silver PTFE audio cable
• DC supply for valve heaters
• Heater circuit floated to minimise heater-cathode noise
• Polished stainless steel chassis
• 6mm solid alloy front & rear plates
• Gold plated Input terminals
• 230/240volts (also 120v), 50watts 1.5A fuse
• Size both units: 148mm W, 165mm H, 342mm D (allow
for connections). Only minimal ventilation required.
• Weight PSU 7kg Pre-amplifier 4kg
• For Shipping 45cm x 48cm x 29cm 14kg (gross packed)
PS3 kun som mm RIAA koster 21.995,-
Læs evt. mere på:
http://highend-sound.com/produkter/icon-audio/forforstaerker/ps3-mk-ii-riaa...
Øvrige informationer om dette tilbud:
Tilbud oprettet: 25-04-2018
Tilbud udløber: 23-05-2018
Garanti: 2 år og 0 mdr.
Pris: 24895 DKK
PS3 mm+mc
Kontakt : HighEnd-Sound
HighEnd-Sound
Østerbakken 3
9310 Vodskov
TLF.: 60 77 24 48
Mail: infohighend-sound.com
Link: http://www.highend-sound.com
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen
Al henvendelse skal ske til den respektive annoncør!
Persondatapolitik  |  Copyright Copyright © 2018 HIFI4ALL.DK - Alle rettigheder forbeholdes
