Faster - For Winning Results You buy a moving coil cartridge for high-performance — so team it with a performance phono preamp for winning results!
The music you listen to should be your choice — your equipment shouldn't dictate your musical taste.
That's the trap many fall into when "upgrading" to moving coil. If in doing so, you find it difficult to listen to your kind of music, read on, and find out why you need this high performance phono preamp.
The Reflex C is supplied with the PSU1 power supply, and a choice of voltages and power plugs; 100 Ω or 1k Ω input impedances; and there is also an option to have a mono switch fitted.
FØLG OS PÅ FACEBOOK. ATTRAKTIV FINANSIERING TILBYDES - KONTAKT OS FOR AT HØRE NÆRMERE.
