Her er du: Tilbudsavisen - Annonce 22. februar 2019 | 13:36
Redaktionelt
Forsiden
Nyheder
Anmeldelser
Indsigtsartikler
Besøgsartikler
Arrangementer
Interaktivt
Køb, Salg & Bytte
Tilbudsavisen
Debat Forum
Services
Kontakt
Søgning
Søg efter produkter i Tilbudsavisen
Udskriv annoncen
Audion - Sterling Anniversary EL34 HW
Annoncør: Blue Cat Audio
Kontakt: kontaktbluecataudio.dk
Produkttype: Intg. Forstærker
Annoncetype: Tilbud
Tilbud:
Audions EL34 Hard wired - lækker lille sag.
På lager - du kan have den 2 dage efter bestilling.
Audion Sterling Anniversary integrated stereo is hard wired point to point using better graded components and & larger Audion wound output transformers (EI96) & hand built. This pentode based EL34 stereo amp uses a small amount of feedback in the design. The chassis is black powder coated aluminum as is the transformer cover. The top plate and badge are mirror finished stainless steel.
This combination makes for smooth transients, good signal handling and tight response curves. There is an audible difference with the Anniversary products, due to the larger transformers and better grade components over the Mk1 printed circuit board models
Amplifier matching
This Sterling is suited for use with loudspeakers of 89db or better efficiency. Ideally matched with our range of Proton cables. The amp delivers 12 watts into 8 ohms. It can be changed internally to work with 4 ohm loudspeakers too. Our integrated model comes with 5 line level inputs and a straight thru tape output switched from the front panel. Options are available for this model, see upgrade options at end.
FØLG OS PÅ FACEBOOK
Læs evt. mere på:
https://bluecataudio.dk/produkt/sterling-anniv-el34-hard-wired/
http://www.audion.co.uk/poweramps/Sterling%20Anniversary%20EL34.html
https://www.facebook.com/bluecataudiodenmark/
Øvrige informationer om dette tilbud:
Tilbud oprettet: 19-02-2019
Tilbud udløber: 19-03-2019
Garanti: 2 år og 0 mdr.
Pris: 18999 DKK
EL34 Hard Wired - Anniversary Edition.
Kontakt : Blue Cat Audio
Blue Cat Audio
Østerbrogade 15
7200 Grindsted
TLF.: 50450661 eller 31375411
Mail: kontaktbluecataudio.dk
Link: http://www.bluecataudio.dk
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen
Al henvendelse skal ske til den respektive annoncør!
Persondatapolitik  |  Copyright Copyright © 2019 HIFI4ALL.DK - Alle rettigheder forbeholdes
