Her er du: Tilbudsavisen - Annonce 23. august 2017 | 02:38
Redaktionelt
Forsiden
Nyheder
Anmeldelser
Indsigtsartikler
Besøgsartikler
Arrangementer
Interaktivt
Køb, Salg & Bytte
Tilbudsavisen
Debat Forum
Services
Kontakt
Søgning
Søg efter produkter i Tilbudsavisen
Udskriv annoncen
SBooster with 2.1 mm connectors and for Squeezebox Duet
Annoncør: Simple Hifi
Kontakt: mailsimplehifi.dk
Produkttype: Tilbehør
Annoncetype: Tilbud
Tilbud:
Få stk haves tilbage af disse, og der kommer ikke flere. Tilbud 150,-......normalt 279,-
The Sbooster Plugs into the existing DC power lead from the manufacturers power supply and then the lead from the Sbooster is plugged into the DC power input socket on the DAC.
The SBooster contains components to reduce the ripple and noise on the DC output of the switch mode power supply that was supplied with the DAC.
The Sbooster can be used at voltages up to 24 Volts DC.
The maximum current ratings at various voltages are as follows:
5V DC 3 Amps max
9V DC 2 Amps max
12V DC 1.5 Amps max
24V DC 0.6 Amps max
If you are not sure of the current consumption of your device you can contact us for advice.
Hi-Fi Choice reviewed the Sbooster in the July 2012 issue and the Sbooster received 5 stars and a Recommended badge.
Read the design philosophy of the SBooster on the manufacturers website sbooster.com
This is a small device and the housing measures approximately 58mm x 33mm. The overall length from end to end of the wires as in the picture is 245mm.
Features:-
Plug and play.
No warranty loss on your device.
Extreme low additional power consumption.
Low price, high quality.
Built with high quality electronic parts.
Læs evt. mere på:
https://markgrant.co.uk/sboosters/20-sbooster-for-squeezebox-duet-871830915...
Øvrige informationer om dette tilbud:
Tilbud oprettet: 30-07-2017
Tilbud udløber: 27-08-2017
Garanti: 2 år og 0 mdr.
Pris: 150 DKK
Kontakt : Simple Hifi
Simple Hifi
Nyrnberggade 54, 3. tv.
2300 København S
TLF.: 42920120
Mail: mailsimplehifi.dk
Link: http://www.simplehifi.dk/
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen
Al henvendelse skal ske til den respektive annoncør!
Persondatapolitik  |  Copyright Copyright © 2017 HIFI4ALL.DK - Alle rettigheder forbeholdes
