Her er du: Tilbudsavisen - Annonce 28. maj 2017 | 22:14
Redaktionelt
Forsiden
Nyheder
Anmeldelser
Indsigtsartikler
Besøgsartikler
Arrangementer
Interaktivt
Køb, Salg & Bytte
Tilbudsavisen
Debat Forum
Services
Kontakt
Søgning
Søg efter produkter i Tilbudsavisen
Udskriv annoncen
Meridian G051+G08
Annoncør: TopSound Hi-Fi ApS.
Kontakt: infotopsoundhifi.dk
Produkttype: Kombi-system
Annoncetype: Demo tilbud
Demo tilbud:
Meridian G051+G08
Meridian receiver + CD afspiller
Outline Specifications
Distortion: Less than 0.01% input to output
Signal/Noise: Better than –90dB for high-level analogue inputs. Better than –70dB for MM input. Better than –60dB for MC input
MM option: Sensitivity adjustable 0.5–3mV rms for 5cm/s @ 1kHz. Overload point 47mV @ 1kHz. Cartridge load 47kΩ + 100 pF
MC option: Sensitivity adjustable 38–210μV rms for 5cm/s @ 1kHz. Cartridge load 220Ω + 10nF
Tuner: AM (Long/Medium Wave, 150–285/525–1605 kHz); FM (VHF Band II, 87.5–108 MHz), sensitivity 2.0μv. Configurable channel spacing & de-emphasis for US/EUR/ Japan, etc
Inputs: 7 unbalanced on phono, 0.5–2.5V rms (impedance 20kΩ) in four steps
Main Output: 2 outputs, 100W per channel into 8Ω
Pre Output: 2 unbalanced on phono, 0–3V rms maximum, 47Ω impedance
Tape Output: 2 unbalanced on phono, 1.5V rms, 47Ω impedance
Headphone: 2V rms maximum output
Comms: Two 5-pin 240° DIN sockets, BNC socket, RS232 and USB comms interfaces
Construction: Meridian black or silver finish in metal & glass
Dimensions: Width: 440mm (17.32in); Depth: 350mm (13.78in) plus connectors; Height: 90mm (3.54in)
Rack Mounting: Kit available from Meridian authorized dealers
Weight: 13.5 kg (29.7 lbs)
Controls: Front-panel soft keys include control of Source, Copy, Mute, etc. Power and Display buttons, volume control. Full remote control of all features via MSR+. Meridian Comms, IR in, RS232, USB
Trigger: 12V trigger output allows switching of external devices
Display: Multi-character dot-matrix Vacuum Fluorescent Display
Power: Versions: 100, 110, 115, 220, 230, 240 Vac, 50/60Hz.Standby 12VA, Idle 50VA, Both channels driven 326VA
G51 rear panel
THD: Better than –96dBFS
Noise: Better than –96dBFS
Mechanism: Triple-beam laser, multi-speed
CD/DVD-ROM transport
Converters: 192kHz-capable, 24-bit, Delta Sigma converters operating at 4 x CD sample rate (176.4kHz)
Outputs: Analogue: 1 unbalanced on phono, 1 balanced on XLR-3M: 2.3V rms fixed, Class A, 47Ω impedance
Digital: S/PDIF (IEC60958), coax and Toslink optical, operating at up to 2 x CD sample rate (88.2kHz), 24-bit
Formats: CD Audio (CD-DA), CD-R, CD-R/W, DTS-CD (bitstream out only: external DTS decoder required)
Comms: Two 5-pin 240° DIN sockets, BNC socket Meridian Comms, and RS232 full remote/configuration interface
Weight: 8.5 kg (18.7 lbs)
Controls: Front-panel soft keys include Play, Stop, Pause, Previous, Next, etc. Buttons for On/Off, Open, Display. Full remote control of all features via MSR+. Meridian Comms (2 x DIN 240º and BNC), IR in and RS232
Power: Universal power supply for 100–240Vac, 50/60Hz, 25W
G08 outline rear panel drawing (actual unit may differ slightly)
Meridian
G51 Integrated AM/FM Stereo Receiver
Demo.sæt i sort
Normalpris kr. 54300,-
Øvrige informationer om dette tilbud:
Tilbud oprettet: 16-05-2017
Tilbud udløber: 13-06-2017
Garanti: 2 år og 0 mdr.
Pris: 19995 DKK
Spar kr. 34304,-
Kontakt : TopSound Hi-Fi ApS.
TopSound Hi-Fi ApS.
Østerbrogade 90
2100 København Ø
TLF.: 35420441
Mail: infotopsoundhifi.dk
Link: http://www.topsoundhifi.dk
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen
Al henvendelse skal ske til den respektive annoncør!
Persondatapolitik  |  Copyright Copyright © 2017 HIFI4ALL.DK - Alle rettigheder forbeholdes
