Her er du: Tilbudsavisen - Annonce 2. juni 2020 | 13:30
Redaktionelt
Forsiden
Nyheder
Anmeldelser
Indsigtsartikler
Besøgsartikler
Arrangementer
Interaktivt
Køb, Salg & Bytte
Tilbudsavisen
Debat Forum
Services
Kontakt
Søgning
Søg efter produkter i Tilbudsavisen
Udskriv annoncen
Musical Fidelity M6si intg. forstærker
Annoncør: Radioactiv
Kontakt: inforadioactiv.dk
Produkttype: Intg. Forstærker
Annoncetype: Tilbud
Tilbud:
Musical Fidelity tilbyder et pris/kvalitetsforhold ingen andre kan matche. Konkurrenterne (også hos de såkaldte direkte til dig) er 50 - 70 % dyrere. Sammenlign bare !
At Musical Fidelity we think of the M6si as being a destination product. The M6si offers such excellent performance, facilities and power that unless you are seeking the most exotic high-end sound quality you would never need another amplifier. We believe it’s that good.
Internally, the M6si is configured as 2 independent monobloc power amps with a separate pre amp. It is, in fact, a pre amp with 2 monobloc power amps that just happen to share the same casework.
The M6si has 220wpc. It has very low distortion, outstanding noise ratio and extremely flat frequency response. Its inputs are phono (MM/MC), 4 line level, 1 balanced XLR and 1 USB ‘B’ up to 24bit 96kHz asynchronous.
The M6 combination of high power, high current and extraordinary stability means that it can drive any loudspeaker with ease.
In use it is hard to hear any practical difference between the M6si and other much more expensive amplifiers. In proper blind listening comparisons, the M6si performs incredibly well. If we sound rather enthusiastic it’s because we are.
We love the M6si and hope that you do too.
M6si In Brief
•220WPC
•Excellent technical performance
•Amazing load driving ability, unconditional stability will drive any loudspeaker
•Wide range of useful inputs including asynchronous USB and switchable MM / MC Phono
•Preamp output
•Internally it is a separate preamp with two independent monobloc power amps; effectively a separates system in a box
•Excellent, hunky build quality
Øvrige informationer om dette tilbud:
Tilbud oprettet: 21-04-2020
Tilbud udløber: 15-06-2020
Garanti: 0 år og 0 mdr.
Pris: 18995 DKK
Kontakt : Radioactiv
Radioactiv
Kirkegade 150
6700 Esbjerg
TLF.: 20974721
Mail: inforadioactiv.dk
Link: http://www.radioactiv.dk
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen
Al henvendelse skal ske til den respektive annoncør!
Persondatapolitik  |  Copyright Copyright © 2020 HIFI4ALL.DK - Alle rettigheder forbeholdes
