Her er du: Tilbudsavisen - Annonce 24. april 2018 | 16:19
Redaktionelt
Forsiden
Nyheder
Anmeldelser
Indsigtsartikler
Besøgsartikler
Arrangementer
Interaktivt
Køb, Salg & Bytte
Tilbudsavisen
Debat Forum
Services
Kontakt
Søgning
Søg efter produkter i Tilbudsavisen
Udskriv annoncen
The Funk Firm SGD
Annoncør: Blue Cat Audio
Kontakt: kontaktbluecataudio.dk
Produkttype: Pladespiller
Annoncetype: Tilbud
Tilbud:
The Funk Firm SGD
The Funk Firm SUPER GRANDE DECK
Ikke pt i vores webshop (det kommer snarest). Er på lager i hvid med valnødde træ på sider - kontakt os for yderligere information.
“Super Deck Grande” or SDG addresses those who need to use up to two 12” arms.
SD Grande’s motor unit is based on Little Super Deck. Being Vector driven one can be assured of the same rock-solid vice-like control on the music.
What you get is Quite Phenomenal solidity.
SD Grande accommodates two arms, a normal 9”: F5, F7 or FX3 and a 12” – both of course standard Rega fitting. The geometry of the 12” being identical to our 12” FXR is based on our F5, which in its mk II guise, Noel Keywood wrote:
“…showing an almost complete absence of the usual tube mode at, or close to, 200Hz” – Noel Keywood HiFi World,
F5 then is an ideal platform upon which to develop a 12” arm: F512, which has now been optimized for use on SD Grande.
A new fixed position, removable headshell permits easy interchangeability for people who use different cartridges. This variant needs no re-alignment, and tracking weight is very easy to re-adjust using our sliding weight system.
The Vector jockey-pulley system radically reduces basic rate wow…It will have the rock sold tonality of a Direct Drive, avoiding the slightly vague-pitch quality of a typical belt drive.
Noel Keywood - Hi-Fi World.
Astonished that this relatively low priced unit has set a new standard for both rumble and Wow and Flutter – “…the best in Audio history”. “Perfect measurements!”
AUDIO Magazine (Germany).
UDEN ARM.
F5 9 tommer arm kan tilkøbes for 5899,-
F5 12 tommer arm kan tilkøbes for 7999,-
Læs evt. mere på:
http://thefunkfirm.co.uk/super-deck-grande/
Øvrige informationer om dette tilbud:
Tilbud oprettet: 14-04-2018
Tilbud udløber: 12-05-2018
Garanti: 2 år og 0 mdr.
Pris: 9999 DKK
SDG her i sort.
Kontakt : Blue Cat Audio
Blue Cat Audio
Markskellet 98
7190 Billund
TLF.: 50450661 eller 31375411
Mail: kontaktbluecataudio.dk
Link: http://www.bluecataudio.dk
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen
Al henvendelse skal ske til den respektive annoncør!
Persondatapolitik  |  Copyright Copyright © 2018 HIFI4ALL.DK - Alle rettigheder forbeholdes
