Her er du: Tilbudsavisen - Annonce 19. oktober 2017 | 03:42
Redaktionelt
Forsiden
Nyheder
Anmeldelser
Indsigtsartikler
Besøgsartikler
Arrangementer
Interaktivt
Køb, Salg & Bytte
Tilbudsavisen
Debat Forum
Services
Kontakt
Søgning
Søg efter produkter i Tilbudsavisen
Udskriv annoncen
Belles Aria
Annoncør: StudioSound
Kontakt: kontaktstudiosound.dk
Produkttype: Intg. Forstærker
Annoncetype: Demo tilbud
Demo tilbud:
Belles Aria
The Belles Aria Integrated Amplifierjju The old adage that the shortest distance between two points is a straight line has application in the realm of high‐end audio.
Specifications:
The Belles Aria Integrated Amplifier specifications are as follows:
Power Amplifier Section:
Power Rating: …………. 75 watts into 8 ohms, both channels driven
……………………………. 125 watts into 4 ohms, both channels driven
……………………… 112 watts peak onto 8 ohms, one channel; driven
……………………….. 175 watts peak into 4 ohms, one channel driven
Damping factor: ………………………………………….. over 2000 at 1kHz
Peak current: ………………………………………………… over 16 amperes
Input Impedance: ……………………………………………….. 47,000 ohms
Input Sensitivity: …………………………………….. 1.2 volts for 75 watts
Gain: ……………………………………………… 21 voltage ratio or 26.4 dB
Frequency Response 3dB: ……………………………….. 0.6 to 100,00 Hz
Noise: ………………………………………………………. greater than 100dB
Line Section:
Frequency Response 3dB: ……………………………….. 1.5 to 250,00 Hz
Distortion: ………………………………….. IM and THD less than 0.001%
Gain: ………………………………………………………….. 3 voltage, 9.54 dB
Noise: ………………………………………………………………… over 100 dB
Moving Magnet Phono Section:
Frequency Response: ……………………… 20 to 20,000 Hz +/‐0.05 dB
Gain: ……………………………………………………………….. 33 dB at 1kHz
Noise: ………………………………………………………………….. over 80 dB
Distortion: …………………………………………………. less than 0.0001%
Headphone Section:
Power: ………………………………… 600 milliwatts onto 30 ohms peak
Functions:
Unbalanced Stereo Inputs: ………………………… 3 line, 1 phono MM,
………………………………………………………….. 1 bypass and 1 monitor
Unbalanced Stereo Outputs: …………………….. 1 speaker, 1 monitor
……………………………………………..1 preamplifier, and 1 headphone
Pushbutton and Remote Controls; ………………………. power, mute,
…………………………………………………………….. Inputs (1,2,3, Phono),
…………………………………………………………… Mon (monitor/bypass)
………………………………………………… and Volume (manual/remote)
Power Rating: ………………………………….. 120 VAC , 5.0 amp SB fuse
…………………………………………… or 200‐240 VAC, 3.15 amp SB fuse
Dimensions: …………………… 16.5″ (419 mm) W x 3.125″ (79 mm) H
……………………….. x 14″ (356 mm) D (excluding jacks and controls)
Shipping Weight: ………………………………………. 30 pounds (13.6Kg)
Læs evt. mere på:
http://www.studiosound.dk/forstaerkere/integreret/belles-aria/
Øvrige informationer om dette tilbud:
Tilbud oprettet: 13-10-2017
Tilbud udløber: 20-10-2017
Garanti: 2 år og 0 mdr.
Pris: 10500 DKK
Kontakt : StudioSound
StudioSound
Toftevej
3250 Søborg Gilleleje
TLF.: 50546919
Mail: kontaktstudiosound.dk
Link: http://www.studiosound.dk
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen
Al henvendelse skal ske til den respektive annoncør!
Persondatapolitik  |  Copyright Copyright © 2017 HIFI4ALL.DK - Alle rettigheder forbeholdes
