Her er du: Tilbudsavisen - Annonce 24. juni 2017 | 12:31
Redaktionelt
Forsiden
Nyheder
Anmeldelser
Indsigtsartikler
Besøgsartikler
Arrangementer
Interaktivt
Køb, Salg & Bytte
Tilbudsavisen
Debat Forum
Services
Kontakt
Søgning
Søg efter produkter i Tilbudsavisen
Udskriv annoncen
Pioneer U 05
Annoncør: TopSound Hi-Fi ApS.
Kontakt: infotopsoundhifi.dk
Produkttype: Hovedtelefoner
Annoncetype: Demo tilbud
Demo tilbud:
Pioneer U 05
High end hovedtelefonforstærker fra Pioneer.
D/A Converter Features
›› 8ch Parallel Drive with SABRE32 Ultra DAC (ES 9016S x 2)
›› US B Input (PCM): 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz,
192 kHz, 352.8 kHz, 384 kHz (16, 24, 32 bit)
›› USB Input (DSD): 2.8 MHz, 5.6 MHz
›› COAXIAL/OPTICAL/AES /EBU Input: 32 kHz, 44.1 kHz, 48 kHz,
88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz (16, 24 bit)
›› Minimum Jitter with Asynchronous Transfer
›› Digital Filter with 3 Modes (SHARP/SLOW/SHORT )
›› Lock Range Adjust Function for Reducing Jitter by Adjusting
Lock Range Accuracy
›› DIRECT Mode for Faithful Reproduction of Original Sound
›› Audio Scaler for up to 384 kHz/32-bit Upsampling
Headphone Amplifier Features
›› Shielded Power Transformer with Independent Winding,
Isolated Power and Digital/Analogue Blocks
›› Full Balance Circuit for Minimum Noise
›› Discreet Circuit Adopted for High-Quality Sound Tuning
›› Balanced Headphone Terminal (XLR3/XLR4) x 2 Compatible with
Recabled Headphones, Unbalanced Headphone Terminal (STD) x 1
›› Fine Adjust Volume Control
›› Gain Switch for Using Headphones with Different Impedance
Audi o Performa nce and Va rious
Other Features
›› Digital Isolator for Reducing USB Block Noise
›› Highly Renowned NEUTR IK Balance Terminals and Machined
RCA Terminals
›› High-Grade Parts Including Pioneer Custom Power Capacitor
›› Variable/Fix Volume Selectable Analogue Output (XLR3/RCA) for
Pre-Amp Function
›› Phase Switch Feature for Line Output
›› Low Centre of Gravity Design with Heavy and Robust Chassis
›› Screw-less Flat Design with Aluminium Front, Top, and Side
Panels
›› Dedicated Remote for Volume and Tone Control
›› Front Display for Detailed Source Information
›› Auto Power Down
USB DAC with Built-in Headphone Amplifier, Featuring SABRE32 Ultra DAC and
U-05-S Asynchronous Transfer
Normalpris kr. 6999,-
Øvrige informationer om dette tilbud:
Tilbud oprettet: 14-06-2017
Tilbud udløber: 12-07-2017
Garanti: 2 år og 0 mdr.
Pris: 4995 DKK
Spar kr. 2004,-
Kontakt : TopSound Hi-Fi ApS.
TopSound Hi-Fi ApS.
Østerbrogade 90
2100 København Ø
TLF.: 35420441
Mail: infotopsoundhifi.dk
Link: http://www.topsoundhifi.dk
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen
Al henvendelse skal ske til den respektive annoncør!
Persondatapolitik  |  Copyright Copyright © 2017 HIFI4ALL.DK - Alle rettigheder forbeholdes
