Her er du: Tilbudsavisen - Annonce 23. juni 2017 | 00:07
Redaktionelt
Forsiden
Nyheder
Anmeldelser
Indsigtsartikler
Besøgsartikler
Arrangementer
Interaktivt
Køb, Salg & Bytte
Tilbudsavisen
Debat Forum
Services
Kontakt
Søgning
Søg efter produkter i Tilbudsavisen
Udskriv annoncen
Sonus Faber Olympica 1
Annoncør: TopSound Hi-Fi ApS.
Kontakt: infotopsoundhifi.dk
Produkttype: Højttalere
Annoncetype: Demo tilbud
Demo tilbud:
Gudesmuk højttaler med en helt forrygende lyd.
SYSTEM
2 way standmount, paralaminar stealth flow vented loudspeaker.
CABINET
Enhanced “Lyre shape” design, progressive thickness triple curvature cabinet walls damped spread resonance spectrum system. Solid walnut vertical clamps.
TWEETER
Sonus faber “Arrow Point” DAD (Damped Apex Dome, synthesis of the classic dome and ring transducer) 29XTR2. A Sonus faber designed 29 mm moving coil driver. The ultra dynamic linearity is given by the new Neodymium motor system.
MID-WOOFER
Sonus faber MW15XTR. A totally Sonus faber designed 150 mm ultra dynamic linearity midwoofer. CCAW wire is used on a composite former “eddy current free” voice coil. The dynamically linear magnetic field motor incorporates triple Kellog/Goeller rings. A special custom diaphragm is made with a real time air dried non pressed blend of traditional cellulose pulp, kapok, kenaf and other natural fibers, developed according to the most natural sound. To further inhibit any residual cone coloration we are using a transparent viscous surface damping coating.
CROSS-OVER
Non-resonant “progressive slope” design, optimized amplitude/phase response for optimal space/time performance. “Paracross topology” on both tweeter hi-pass and midwoofer low pass, cross-over point 2.500 Hz.
FREQUENCY RESPONSE
50 Hz – 30.000 Hz, tuning port included.
SENSITIVITY
87 dB SPL (2.83 V/1m).
NOMINAL IMPEDANCE
4 ohm.
SUGGESTED AMPLIFIER POWER OUTPUT
40W – 150W, without clipping.
LONG-TERM MAXIMUM INPUT VOLTAGE (IEC-268-5)
20V rms.
DIMENSIONS
354x222x368mm
Normalpris kr. 19495,-/stk
Øvrige informationer om dette tilbud:
Tilbud oprettet: 15-06-2017
Tilbud udløber: 13-07-2017
Garanti: 2 år og 0 mdr.
Pris: 14995 DKK
Spar kr. 4500,-
Kontakt : TopSound Hi-Fi ApS.
TopSound Hi-Fi ApS.
Østerbrogade 90
2100 København Ø
TLF.: 35420441
Mail: infotopsoundhifi.dk
Link: http://www.topsoundhifi.dk
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen
Al henvendelse skal ske til den respektive annoncør!
Persondatapolitik  |  Copyright Copyright © 2017 HIFI4ALL.DK - Alle rettigheder forbeholdes
