NightRhyme Forum Bruger
Bruger siden: 28 September 2005 Lokalitet: Aalborg
Status: Offline Indlæg: 240
Sendt: 06 Juli 2010 kl. 17:20 | IP-adresse registreret
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/popup_ad p.php?p_faqid=2698
Media File Formats Supported on the original WD TV HD Media Player(WDAVx00) (Based on Firmware Version 1.03.01)
Video -- WMV9, AVI (MPEG1/2/4, Xvid, AVC), H.264, MKV (h.264, x.264, AVC, MPEG1/2/4, VC-1), MOV (MPEG4, H.264),
MT2S, TP, TS, MOV/MP4 (MPEG4, h.264), DVR-MS, VOB (unprotected or unencrypted)
MPEG2/4, H.264, and WMV9 support up to 1920x1080p 24fps, 1920x1080i 30fps, 1280x720p 60fps resolution.
FLV file extensions are NOT supported. Neither are RMVB videos from Real Media. You will need to use conversion software
to convert them to a supported format.
The WD TV HD Media Player only supports certain types of codecs based on the extension of your file. You can check the
User Manual for a list of supported codecs for each file extension.
Pictures -- JPEG/JPG, GIF, TIF/TIFF, BMP, PNG
JPEG only supports compressed RGB format files. BMP only supports uncompressed files. TIFF only supports single layer
files. BMP, TIFF/TIF, PNG, and GIF have a max resolution of 2048x2048. JPEG/JPG has a max resolution of 4096x4096 unless
it is in a progressive format, then maxes out at 1280x720.
Audio -- MP3, WMA, MPA, M4A, MP4A, OGG, WAV/PCM/LPCM, AAC, FLAC, Dolby Digital, AIF/AIFF, MKA
An audio receiver is required for surround sound output (including the unsupported DTS audio codec). For more information
see Answer ID 3590: DTS support on the WD TV Media Player
AAC/Dolby Digital decodes in 2 channel output only.
Playlists -- PLS, M3U, WPL
Subtitles -- SRT, SMI, SUB, ASS, SSA
Note: Be sure to check our Downloads Library for for the latest firmware. You will also find Release Notes showing what
functionality has been added with the update.
Media File Formats Supported on the WD TV Live HD Media Player and and WD TV HD Media Player (WDBABx) (Based on
Firmware Version 1.02.21 for the WD TV Live HD Media Player and 1.01.77 for the WD TV HD Media Player)
Video -- MPEG1/2/4, WMV9, AVI (MPEG4, Xvid, AVC), H.264, MKV, MOV (MPEG4, H.264), MT2S, TP, TRP, TS, MP4, ASF, VOB
The WD TV Live HD Media Player only supports certain types of codecs based on the extension of your file. You can check
the User Manual for a list of supported codecs for each file extension.
Audio -- MP3, WAV/PCM/LPCM, WMA, AAC, FLAC, MKA, AIF/AIFF, OGG, Dolby Digital, DTS
AAC/Dolby Digital/DTS decodes in 2 channel output only. You will need an audio receiver capable of decoding these codecs
for additional channels.
Subtitles -- SRT, ASS, SSA, SUB, SMI
Note: Be sure to update your WD TV Live HD Media Player to the latest firmware.
