Tilbage til HIFI4ALL.DK 27. april 2024 | 06:26
Emne Emne: Rep. af Quad 66? (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
clauskri
Bruger siden: 22 November 2007
Sendt: 08 Maj 2017 kl. 09:56 | IP-adresse registreret
Min svoger, som er englænder, har en Quad 66 preamp som driller. Han bor i Fredericia og jeg i Aarhus.
Findes der en elektronikkyndig i enten Aarhus eller Fredericia omegnen, der kunne være behjælpelig med at kigge på det??
Det er sådan en fætter her - jeg aner ikke om det kan betale sig?
https://www.hifiengine.com/gallery/images/quad-66-pre-and-60 6-power.shtml
på forhånd tak
Til top Vis clauskri's Profil Søg efter andre indlæg skrevet af clauskri
clauskri
Sendt: 08 Maj 2017 kl. 10:20 | IP-adresse registreret
her er min svogers beskrivelse af problemet - det kan sikkert spore nogen ind på problemet?
Hi Claus - thanks so much for this - that's really a help as I have no idea about the network in Denmark for these things :)
So the problem is with the Quad 66 pre-amp: I powered it on one day and the display looked corrupted - it was stuck on AV input, the EQ filters and EQ tilt display was activated which I never used) and none of the remote controls would work. I tried connecting the remote control directly (there is a special cable to plug in) and it didn't make any difference. And there was no audio path, even through AV.
I suspect that a chip controller has blown, because of the corrupted display - here's a photo which I took at the time, which I thought was slightly funny because it seems the amplifier is saying "ouch" in Danish ;)
The lines marked "2" is the EQ tilt function, of course I would always use it with flat EQ  - so something in the electronics for control has gone kaput I think :-/
Thanks so much! See you next weekend!
clauskri
Sendt: 11 Maj 2017 kl. 06:38 | IP-adresse registreret
Overhovedet ingen der har forstand på det og kunne være behjælpelige.
Tonni
Bruger siden: 05 Februar 2006
Sendt: 11 Maj 2017 kl. 08:35 | IP-adresse registreret
Ville ringe til Lars fra Sound2Vision i Viborg.
Bare det GLØDER...
clauskri
Sendt: 11 Maj 2017 kl. 19:22 | IP-adresse registreret
Det er en mulighed. Vil dig i første omgang gerne holde det inden for det geografiske felt jeg efterspørger.....
Tonni
Sendt: 12 Maj 2017 kl. 11:36 | IP-adresse registreret
Eksisterer Vejle Radio og TV stadig? De havde et godt ry, da jeg var i branchen (15 år siden)...
Bare det GLØDER...
